  3. Check for duplicate BATID's
5 Posts 2 Posters 1.9k Views
    BartJeurissen
    Is it possible to make a rule which checks wether there are duplicate BATID’s in a model?
    This sometimes happen when for instance floors or ceilings are modelled as one object in Revit but are exported as 2 or more elements to IFC.
    I have tried several rules but couldn’t find one which worked.
    Underneath an example in Solibri:
    Same BATID with different GUID in the same model:
    • mjkayaliM Offline
      mjkayaliM Offline
      mjkayali
      you may use the information take off and add a column of the batIds and enable grouping only for that column. so when a row counts more than one object then you can find the double or more objects with the same BatId. i think also its easier to export the ITO to Excel and search the doubles there
        BartJeurissen
        Yes I thought of that to, however I would like to have it also as a rule.
        Then if engineers run the ruleset they will get an error…
        • mjkayaliM Offline
          mjkayaliM Offline
          mjkayali
          wrote on last edited by mjkayali
          Have you tried the rule 21 (Components Must Have Unique Identifier) ?
            BartJeurissen
            Great, thanks very much.
            I must have mist that one.
