  3. Clashes that are grouped by default shows different elements than single issue?
3 Posts 2 Posters 720 Views
  • IngarsI Offline
    IngarsI Offline
    Ingars
    Can you please someone explain why this is happening?
    After checking is done - I usually select a group of issues and make a view/issue with it, not one by one like this:
    1st view
    But when I select the issues with [shift] which are under this group - it shows different issues:
    2nd view
    Is it somehow related to the model update (previously the 1st view showed similar issues as in the 2nd view)? It updated the models but not the issues after a new check. Well, it’s weird because it just doesn’t make sense when the group is showing different elements than the singular issues in the group. hm…
    Maybe you had such an experience and know how to exclude this situation, well I wouldn’t like to reload the check all the time after the model update because then I would lose any checking done/accepted or rejected.
    Thanks 🙂
    • F Offline
      F Offline
      fwassmann
      I can`t reproduce this behavior. When i select the topic issue it shows the same Elements as if i select all the Issues underneath all together.
      IngarsI 1 Reply Last reply
      • IngarsI Offline
        IngarsI Offline
        Ingars
        replied to fwassmann on last edited by
        @fwassmann Then it must be bugging cuz of an old SMC file… ;/, thanks
