  3. Which rule to check that a property value doesn't contain a certain letter?
9 Posts 6 Posters 1.9k Views
  • Mats_KnutssonM Offline
    Mats_Knutsson
    wrote on last edited by Mats_Knutsson
    I kind of got stuck on this probably super simple thing…
    Mats
      230?
      There is no “does not contain” so using “None of” should be the way to go.
      However, there is a bug or a feature? Afaik the first time the list entries are created you cannot modify the entries unless you close/open Solibri or the ruleset. Then it should work. @Solibrians are you aware of that?
      Mats_KnutssonM M 2 Replies Last reply
      • paola bronzoP Offline
        paola bronzo
        Adding “does not contain” is not a bad idea at all!
          Mats_Knutsson
          replied to JSN on last edited by Mats_Knutsson
          @JSN said in Which rule to check that a property value doesn’t contain a certain letter?:
          230?
          Aha …must be a bug. I got it working…thanks 🙂
            manuel.furia Solibrians
            @JSN Hi, regarding this: “Afaik the first time the list entries are created you cannot modify the entries”. Which version of Solibri were you using? Was is 9.13.5 or earlier?
              replied to manuel.furia on last edited by
              @manuel-furia said in Which rule to check that a property value doesn’t contain a certain letter?:
              9.13.5
              Yes, 9.13.5.12
                @JSN Can you tell the exact sequence which does not work when you say “Afaik the first time the list entries are created you cannot modify the entries”?
                At least I can do the following:
                1. Press add value
                2. I need to choose some value from the list to add it to the selected values:
                3. After that I can go and edit the value as I want (need to double-click on it):
                  @Pasi-Paasiala
                  Sure. What is my mistake?
                  Animation1.gif ,
                  • jakub.rusinJ Offline
                    jakub.rusin Solibrians
                    @JSN @Pasi-Paasiala @manuel-furia
                    Seems that some Properties have this problem and other don’t
                    Layer, Building, Discipline, Federated Floor (and possible other) are not editable.
                    Application, Name (and others) are editable.
                    I will create a ticket for this.
