  3. Sort out wrong Property Set name
3 Posts 2 Posters 723 Views
    Sverre
    I have a large SMC with multible models from different subcontractors. Obviously som have named their Property set wrong beacuse when I choose the drop down I got 2 alternatives on the same Property set. Example correct property set name: System_123. Example wrong property set name: SYSTEM_123. Is there an easy way to use Classification or Ruleset to sort out hte models or objects that has this wrong “spelling” in the name? I tried ITO with the correct and the incorrect name but the ITO cant find the difference, in a case sensitive example like this. Hope this makes sense.
      Sverre
      No one knows how to fix this problem?
        replied to Sverre on last edited by
        Within Solibri? If the out-of-pocket solutions including all kind of rules for property checking all don’t care about case sensitivity then you could for example make use of a JavaScript column.
