  3. Automatic update IFC models
2 Posts 2 Posters 907 Views
    silje_kk
    Shot version:
    1. Does anyone know how I can get a list of all the file paths of the models in my Solibri model? Ex. with the help of an ITO?
    2. Does anyone else has a problem with the xml code line <autoupdatemodels/>?
    Long version:
    For some reason the xml code line <autoupdatemodels/> does not seem to work with my Solibri v. 9.13.4.19. Does anyone else have a problem with this code line?
    I want to update all the ifc models in my Solibri model every night. Today I do this with an xml, where I list all the filepaths and use the code line <updatemodel file=“C:…” for each model. Not very efficient when the models are replaced/changed ++.
    So now my plan B is to create the xml (that updates the Solibri model) with the “<updatemodel…” lines that is also automatically updated, like this:
    0. Open the Solibri model (#1 xml)
    1. Automatically export an ITO with the filepaths (#1 xml)
    2. Create a script that translate the ITO to an xml with the “<updatemodel…” lines (script)
    3. Run the new xml that update all the correct filepaths. (#2 xml)
    Hope someone can help me 🙂
    S
      lucasmello
      wrote on last edited by lucasmello
      I don’t know if I can help you, but I use this XML structure below to update models:
      <?xml version=“1.0” encoding=“ISO-8859-1”?>
      <batch name=“UPDATE MODELS” default=“root”>
      <target name=“root”>
      <openmodel
        file="C:..." />
      <autoupdatemodels/>
      <savemodel
        file="C:..." />
      <exit />
      </target>
      </batch>
      And to make it run at night, I use the Task Scheduler to run a .bat file like this:
      @ECHO off
      ECHO Autorun operating…
      ECHO Please wait…
      REM In the line below, you change the path to the SMC file for autorun.
      “C:\Program Files\Solibri\SOLIBRI\Solibri.exe” “(xml path) C:…”
      exit
