  3. A filter issue with property
5 Posts 4 Posters 1.2k Views
  • H Offline
    H Offline
    HieuVH-FPT
    Hi Solibrians,
    I hava a filter like this
    Property setting:
    Window components don’t have that property.
    When I put blank to Value, filter doesn’t return any components
    But i put a space to Value, filter returns components.
    Can you explain for me? i think if components don’t have property, filter always doesn’t return any components
      There is an operator “is defined” that checks if the property exists.
      By adding “is defined” you can check that the property value is not a blank.
        tungns8fsoft
        @Matti-Kannala we have no problem with other operators, we just want to confirm is this expected behavior?
        I anticipate that with a non-existent property, irrespective of the value or operator used, it should yield consistent results. Why the one with a single space in value return components when other do not?
        Include + Wall + a.b + None Of + Null
        should be equal to
        Include + Wall + a.b + None Of + Space
        because property a.b does not exist in the entire model.
          @tungns8fsoft Could you save these filters to files and share, so it’ll be easier to duplicate what you’re saying?
          Also is this related to filtering in general, or to a specific rule?
            tungns8fsoft
            wrote on last edited by tungns8fsoft
            @Pasi-Paasiala It’s filtering in general, not relate to any rule.
            Filter.zip
