  3. BCF Live Connector to Trimble Connect FILE_NAME
16 Posts 7 Posters 5.1k Views
    lraimo
    @Wing-Mang
    Thank you for the code.
    By the way, my testing has shown ifc FILE_NAME in Solibri must be the same as the file name in Trimble Connect. So the last step in your workflow (sync back to TC) is actually redundant
    • H Offline
      H Offline
      Hamo
      WE communicated the Problem with Solibri and Connect. This is the result:
      This issue was discussed between the Trimble Connect dev team and the Solibri dev team. The conclusions are:
      1. Immediate Workaround is: go to the IFC file and change the IFC file name header
      2. Solibri improvement identified: Solibri plans to add a user setting so that: “Add option to map model name based on file name OR the IFC header file name”. Please look for an upcoming new release of the Solibri Office.
      • paola bronzoP Offline
        paola bronzo
        Hi @Solibrians ,
        Do you have any updates on how to resolve the problem?
        Or does @Hamo 's answer above always apply?
          BCF-API 3.0 has a solution for this. We’ve communicated with Trimble that they could update their implementation.
            paola bronzo
            Sorry @Pasi-Paasiala, does this mean that the problem has already been fixed in the last versione 9.13.7 and that the synchronization between Solibri and Trimble Connect works well now? Or does Trimble still have to apply the solution?
            Thanks.
              @paola-bronzo Trimble would need to implement BCF-API 3.0. In the meanwhile we’re working on a workaround.
                lraimo
                This has been fixed in Solibri 9.13.8 Beta
                S 1 Reply Last reply
                  Sander E
                  replied to lraimo on last edited by
                  @lraimo Where can i get the 9.13.8 beta?
                    lraimo
                    @Sander-E
                    You have to join Solibri Beta Program!
                    https://society.solibri.com/topic/740/join-our-solibri-beta-program
                      This is now done in Solibri 9.13.8.
                      https://society.solibri.com/topic/2826/solibri-9-13-8-has-been-released
                        Sander E
                        wrote on last edited by Sander E
                        Thanks. It is done; Issues from Solibri to Trimble Connect it is working… BUT… Issues from Trimble to Solibri did not working.
                        I am figuring out if this is a problem related to the File name/IFC name header or something else.
