  3. Still don't understand about format of Property Reference Parameter
6 Posts 2 Posters 1.3k Views
  • H Offline
    H Offline
    HieuVH-FPT
    Hi Solibrians
    When I tried to get value from property with above settings, I got “102” as value.
    But when I change to below setting, I got “0.102” as value.
    I used code to check type of returned value and both of them are intanceof Double
    What is difference between them? Can you explain for me?
      replied to HieuVH-FPT on last edited by
      @HieuVH said in Still don’t understand about format of Property Reference Parameter:
      You can define the unit measures and how they are shown within Solibri in your settings.
      H 1 Reply Last reply
      • H Offline
        H Offline
        HieuVH-FPT
        replied to JSN on last edited by HieuVH-FPT
        @JSN said in Still don’t understand about format of Property Reference Parameter:
        I think settings aren’t the problem.
        My problem is with different format the returned values are different and I want to know why is that.
          replied to HieuVH-FPT on last edited by JSN
          @HieuVH
          Ah with the added details I see now what you mean. What is the actual IFC datatype of your property?
          The unit settings matter as in the example below you see that the same property (or quantity) is displayed differently depending on which datatype I chooses for the property as the default SI Unit within my IFC file is set to mm whilst the Solibri lenght measure unit is specifically set to m …
          (Btw, I think by today Solibri is only able to detect global unit assignments from the IfcProject and not by each nominal value, but I am not 100% sure)
          Therefore the displayed value is different based on the settings you have set.
          I am not sure how Solibri internally handles ‘Text’ that seems to be detected as e.g. a double value but I also detected some anomalies in the past. See also here where an integer is shown while it seems to be a double value behind the scenes https://society.solibri.com/topic/2612/ifccountmeasure?_=1710187339623
          So probably a mix of both is happening to you here as well. I would suggest you to provide an example file, otherwise it is hard to guess what’s the matter.
          • H Offline
            H Offline
            HieuVH-FPT
            wrote on last edited by HieuVH-FPT
            @JSN said in Still don't understand about format of Property Reference Parameter:
            I’m not related to IFC but it’s shown in Solibri
            I try to get the value through API Component.getPropertySets() and it also returns “102” as Double value.
            One more example is this one:
            When I get value through Property Reference Parameter, it returns “5000” as Double value with “Text” format and returns “5.0” as Double value with “Length” format.
            With Component.getPropertySets() API, it returns “5.0” as Double value.
              @HieuVH
              Seems legit.
              I guess your property is defined by sth like
              #12345=IFCPROPERTYSINGLEVALUE('YourPropertyName',$,IFCREAL(102.),$);
              Your IfcUnits are probably mm but the specified lenght units in Solibri might be m in your first example with 3 digits shown?
              Though I am not sure then why in your second example you suddenly have 5k mm with 6 decimals shown. But it would make sense that it is actually 5(.0) meters in your file (which might be a different one/having different units (m) assigned?)
              So ‘Text’ is just sth. that acutally exists within Solibri. In fact the value specified in the IFC is derived via getPropertyValue () which brings me back to my first reply
              Here also an Example of an IfcReal
              which shows “your values” when you willfully change the datatype in the column settings.
              The same IfcReal as Double | Text | Lenght from left to the right …
