Sectioning Settings exclude Rooms
Hello there,
I would like to use the sectioning Setting to fill sectioned objects from the architecture model. But it also has room elements in it, so if I use the fill option all my rooms are now solid and I can´t really see anything in 3D without hiding the rooms first.
rooms visible
rooms hiddenHas anybody a good solution for that? Even with the extended setting I only can difference the complete discipline like architecture, heating etc and not the different elements from architecture like all spaces.
Best regards
@Solibrians ist there any solution for this ?
@HechtwieFisch By default rooms are not visible in Solibri. Is there a reason you want to have them visible when doing sectioning?
@Pasi-Paasiala No i don´t want them visible
maybe my workflow is wrong or i´m missing something?- I´m in the results window looking at some clashes
- I want to see the clash in the context with the whole architecture model
- I create a section
- I use the model structure to show the whole architecture model with +
- now the rooms are visible and i can´t see anything so I hide them with alt + S
I know it is only one small step but if it is possible I would like to avoid it
@JSN Thanks a lot for the answers! As I’m not the model author and we need the rooms normally, the first solution is not feasible. The second one I’m already using but wanted to know if there was a way around it. But the third I had thought about but I never try making them fully transparent (as everything lower than 100% is not working)
@HechtwieFisch Thanks for the workflow.
I have a similar issue where I do want to see the room, but there is not an easy distinction between
- an enclosed volume (the room)
- a surrounded empty space surrounded by the room)
Here is how the IfcSpace looks like:
And how it looks when I cut through:
You see a slightly different opacity, but once the rest of the building is in the background this becomes impossible.
Any way to solve that?
@Alex-J Would it be possible to have a simple IFC file that duplicates this issue?
@Pasi-Paasiala I’ll look into it
@Alex-J said in Sectioning Settings exclude Rooms:
The holes are filled in sections ATM. We have not yet implemented this.
@Matti-Kannala said in Sectioning Settings exclude Rooms:
Do you still need a test file then @Pasi-Paasiala ?
@Alex-J Test model certainly doesn’t harm.
@Pasi-Paasiala said in Sectioning Settings exclude Rooms:
Here it is, I finally got around to find a nice example
TestFile_RoomSection.ifc -
Hi @Pasi-Paasiala,
just to let you know this issue is still cumbersome.Here’s another example with a wall opening:
cutting in front of it:
cutting through it:
You can see the visibility is quite bad when the plane goes through it.
