Checking rule for items mount in or on drop-ceilings
Hi.
Need help choosing and filter for a ruleset to find MEP items mounted in directly under drop-ceilings.
I have to a degree had some success used rule 1/5.0 to finding items going thru the ceiling like sprinkler-head, but it doesn’t seems to see everything, or possible I haven’t understood all the settings and/or filters. But when it comes to MEP items mounted on the ceiling surface fx a WIFI AP I have tried with rule 222/4.3 and 226/3.1 with no success.Could someone guide me in the right direction?
Regards,
Joel Young -
can you make screenshots of youre settings of the different rules.
it’s hard to say what is going wrong with no information -
Sorry for the late response, just too many things going on, and testing out different settings. This is my checking at the moment, which fails in find everything.
Let me show some results what it finds and what is there.
First room result:
What is there in reality:
Second room:
Reality:
It is the same in every single room, some items is found, but not all and not consistently. Have tried using “Minimum Distance” 0 mm up to 10 mm. The result vary from check to check, but never find everything in each area
Did you try to switch to max distance? try to set Max distance to 5mm
