  3. Updating presentation from BCF file Bug
8 Posts 2 Posters 1.3k Views
  • HamzalaalaouiH Offline
    Hamzalaalaoui
    I have been experiencing an issue lately. When I try to update the presentation from a BCF file, I get the file explorer window and select the BCF file. Normally, all the slides get updated, but sometimes the slides don’t update. When I try again to update the presentation, the file explorer to select the BCF file doesn’t show up.
      Hamzalaalaoui
      Bug fixed in the latest version
        Hamzalaalaoui
        Some fixes i found :
        • Rename the BCF file is it is too long
        • Make the path to the bcf file shorter, otherwise Solibri won’t read it
          @Hamzalaalaoui What was the full path of the original file?
            Hamzalaalaoui
            P:\PUBLIC\PROJ\2017\17 060 ARCELORMITTAL HEADQUARTER 2020 A LUXBG\BIM\3_Analyse maquettes\1-Contrôle Maquette\Rapport 06-11-2024 (R+5 et R+6)\Indice AA\SUIVI\LT678\AMHQ-EXE-LT8A-010-RA03-TZ-TN-0008-AA
              @Hamzalaalaoui And what was the path that worked?
                Hamzalaalaoui
                  @Hamzalaalaoui Can you once more try to import from the longer path and send the runtime.log that’s in the log folder of your Solibri installation?
                  Before you do this, you can delete the runtime.log, so it won’t have info about anything else.
