  3. Supported Functions in Solibri Formulas
1 Posts 1 Posters 1.7k Views
  • tonigyllenbergT Online
    Below are the supported functions available in Solibri Formulas:
    Logic Functions
    • AND – Returns TRUE if all arguments are true.
      Syntax: AND(value1; value2; ...)
    • IF – Returns one value if a condition is true, another if false.
      Syntax: IF(condition; value_if_true; value_if_false)
    • IFERROR – Returns a value if an expression results in an error.
      Syntax: IFERROR(value; value_if_error)
    • NOT – Returns the logical negation of an argument.
      Syntax: NOT(value)
    • OR – Returns TRUE if any argument is true.
      Syntax: OR(value1; value2; ...)
    Math Functions
    • ABS – Returns the absolute value of a number.
      Syntax: ABS(number)
    • ACOS – Returns the arccosine of a number.
      Syntax: ACOS(number)
    • ASIN – Returns the arcsine of a number.
      Syntax: ASIN(number)
    • ATAN – Returns the arctangent of a number.
      Syntax: ATAN(number)
    • ATAN2 – Returns the arctangent of the quotient of two numbers.
      Syntax: ATAN2(x number; y number)
    • AVERAGE - Returns the average of a list of numbers.
      Syntax: AVERAGE(number1; [number 2]...)
    • COS – Returns the cosine of a number.
      Syntax: COS(number)
    • DEGREES – Converts radians to degrees.
      Syntax: DEGREES(angle)
    • CEILING – Rounds a number up to the nearest integer.
      Syntax: CEILING(number)
    • FLOOR – Rounds a number down to the nearest integer.
      Syntax: FLOOR(number)
    • INT – Returns the integer part of a number.
      Syntax: INT(number)
    • MAX – Returns the maximum value from a list.
      Syntax: MAX(number1; number2; ...)
    • MIN – Returns the minimum value from a list.
      Syntax: MIN(number1; number2; ...)
    • MOD – Returns the remainder of a division operation.
      Syntax: MOD(number; divisor)
    • PI – Returns the value of π (pi).
      Syntax: PI()
    • POWER – Raises a number to a specified power.
      Syntax: POWER(base; exponent)
    • PRODUCT – Returns the product of a list of numbers.
      Syntax: PRODUCT(number1; number2; ...)
    • RADIANS – Converts degrees to radians. Syntax: RADIANS(degrees)
    • ROUND – Rounds a number to a specified number of decimal places.
      Syntax: ROUND(number; num_digits)
    • ROUNDDOWN – Rounds a number down to a specified number of decimal places.
      Syntax: ROUNDDOWN(number; num_digits)
    • ROUNDUP – Rounds a number up to a specified number of decimal places.
      Syntax: ROUNDUP(number; num_digits)
    • SIN – Returns the sine of a number.
      Syntax: SIN(number)
    • SQRT – Returns the square root of a number.
      Syntax: SQRT(number)
    • SUM – Returns the sum of a list of numbers.
      Syntax: SUM(number1; number2; ...)
    Text Functions
    • CONCAT – Concatenates multiple strings into one.
      Syntax: CONCAT(text1; text2; ...)
    • EXACT – Checks if two strings are exactly the same.
      Syntax: EXACT(text1; text2)
    • FIND – Returns the position of a substring within a string.
      Syntax: FIND(substring; text; start_num)
    • FIXED - Formats a number as text with a fixed number of decimal places.
      Syntax: FIXED(number;[decimals];[no_commas])
    • LEFT – Returns the left part of a string.
      Syntax: LEFT(text; num_chars)
    • LEN – Returns the length of a string.
      Syntax: LEN(text)
    • LOWER – Converts a string to lowercase.
      Syntax: LOWER(text)
    • MID – Extracts a substring from the middle of a string.
      Syntax: MID(text; start_num; num_chars)
    • PROPER – Capitalizes the first letter of a string and converts the rest to lowercase.
      Syntax: PROPER(text)
    • RIGHT – Returns the right part of a string.
      Syntax: RIGHT(text; num_chars)
    • TRIM – Removes leading and trailing spaces from a string.
      Syntax: TRIM(text)
    • UPPER – Converts a string to uppercase.
      Syntax: UPPER(text)
    • VALUE – Converts a string to a number.
      Syntax: VALUE(text)
    Validation & Info Functions
    • ISBLANK – Checks if a value is blank.
      Syntax: ISBLANK(value)
    • ISLOGICAL – Checks if a value is a logical value (TRUE or FALSE).
      Syntax: ISLOGICAL(value)
    • ISNONTEXT – Checks if a value is not text.
      Syntax: ISNONTEXT(value)
    • ISTEXT – Checks if a value is text.
      Syntax: ISTEXT(value)
    • ISNUMBER – Checks if a value is a number.
      Syntax: ISNUMBER(value)
    • CHOOSE – Returns a value from a list based on an index number.
      Syntax: CHOOSE(index_num; value1; value2; ...)
    Operators
    • + – Addition: Adds two values.
      Example: 5 + 3 → 8
    • & – Concatenation: Joins two strings together.
      Example: "Hello" & " World" → **“Hello World”`
    • / – Division: Divides one number by another.
      Example: 10 / 2 → 5
    • = – Equality: Checks if two values are equal.
      Example: 5 = 5 → TRUE
    • > – Greater Than: Checks if one value is greater than another.
      Example: 10 > 3 → TRUE
    • >= – Greater Than or Equal: Checks if one value is greater than or equal to another.
      Example: 3 >= 5 → FALSE
    • < – Less Than: Checks if one value is less than another.
      Example: 2 < 10 → TRUE
    • <= – Less Than or Equal: Checks if one value is less than or equal to another.
      Example: 7 <= 7 → TRUE
    • * – Multiplication: Multiplies two values.
      Example: 4 * 3 → 12
    • != – Not Equal: Checks if two values are not equal.
      Example: 8 != 5 → TRUE
    • ^ – Power: Raises a number to a power.
      Example: 2 ^ 3 → 8
    • - – Subtraction: Subtracts one value from another.
      Example: 9 - 4 → 5
    • tonigyllenbergT tonigyllenberg has marked this topic as solved on
    • tonigyllenbergT tonigyllenberg pinned this topic on
