  3. ITO - Formulas
ITO - Formulas
3 Posts 2 Posters 616 Views
  • HamzalaalaouiH Offline
    Hamzalaalaoui
    I am trying to understand an abnormal behaviour in ITO formulas. My objective is to verify whether the building storey name corresponds to the correct elevation. For example, I am using the following formula:
    IF(AND(C=“E-R+1b”; D=“220,050”); “OK”; “Non conforme”)
    However, even when the first row is correct, the column still returns values where both conditions are not met.
      wrote on last edited by Matti
      For the numeric values I recommend compare value with tolerance
      IF(ABS(target - actual) <= tolerance;“OK”;“NOT OK”)
        Hamzalaalaoui
        Thank you soo much for your reply, i have managed to find a solution similar to this where i creat a column that is equal to colum D to fix the unit of elevation and then in another column compare between the target number and actual.
        Have a nice day
