Update Prompt
Why does de update Prompt not appear as aspected.
For some time now, it hasn’t always appeared, making it unreliable.
This is important because, unfortunately, collaborating on a single model isn’t possible within Solibri.
That’s why it’s important for everyone to work with the latest versions of the IFCs, which isn’t currently possible because we can’t see that a new model has been added to the folder.
The only way to do this seems to be the old-fashioned way: sending a message to all team members with a notification.We’ve been working with a network drive that stores the project files for several years now.
We never had any problems with this before, and nothing has changed in that regard. -
@BvanDalsum
This might be related to authentication.
In Solibri, you can choose to have your login credentials remembered—which is certainly more convenient, as it saves you from having to log in to ACC or SharePoint every single time.
However, at our company, you are required to re-authenticate every three weeks.
If this isn’t done, it can sometimes look like you have an active connection, when in reality, you no longer do.
Therefore, re-establishing the connection once a day or once a week might help, and would likely resolve the issue with the prompt. -
that is not the case here,
This isn’t about an environment you have to log into.
If you’re connected to the network via an Ethernet cable or Wi-Fi, you have access to this drive.
What strikes me first is how the update behaves.
Sometimes the prompt appears within a few seconds, and sometimes it doesn’t appear at all.
