  3. Clearance in-front of escalators
4 Posts 2 Posters 1.3k Views
  • alex.nesbittA Offline
    alex.nesbitt
    Hello everyone.
    I am looking for some advice on creating a check for whether there is a 6m clearance at the top and bottom of escalators to allow for queuing. Hopefully this illustrates what I am looking for:
    The example I am trying to fail is this instance of an elevator placed 3.35m from the end of the escalator:
    So far I have tried:
    1. Rule SOL/222/4.2 - Component distance using the “Facing within distance” and “Horizontal distance between footprints” option:
    1. Rule SOL/226/3.0 - Free Area in Front of Components - this failed miserably:
    My thoughts are we’ll need Solibri to identify the top and bottom of the escalator, determine the correct facing direction and then run a minimum distance check.
    Any other ideas to try?
    • Nicola TessaroloN Offline
      Nicola Tessarolo
      wrote on last edited by Nicola Tessarolo
      Hello Alex 👋
      Maybe the rule SOL/210/3.1 is something that holds the key to your question.
      If you set it up, you can use the classifications to create a group for all those escalators in your model.
      Afterwards, you can define what the minimum of free space at the beginning and at the ending should be.
      The results should present themselves to you in some way like this:
      or like this:
      Maybe this will help you in achieving your goals! 😄
      Many regards from Switzerland, take care 👋
      Nico
      Nicola Tessarolo
      BIM Consultant
      CAD & Solibri Support / Coach
      IDC AG
      Kägiswilerstrasse 29, 6060 Sarnen
      [email protected]
      Tel.: +41 41 368 20 70
      www.idc.ch
        alex.nesbitt
        Excellent thank you! Let me give it a go.
          Nicola Tessarolo
          You are very welcome, I hope it works the way you wish to! 🙏
          Nicola Tessarolo
          BIM Consultant
          IDC AG
          [email protected]
          www.idc.ch
