  3. Rule 203 fails on zero?
4 Posts 2 Posters 847 Views
  • _c__ Offline
    _c__ Offline
    _c_
    we have a rule 203 where an integer is required representing the count of sashes in Windows. By windows with fixed element there are no sashes: count is zero…
    The rule doesn’t accept zero, though, it fails with “missing properties”.
    Does anybody know how to force it to accept zero? Zero Is a legit option.
    c
      wrote on last edited by Matti
      @_c_ said in Rule 203 fails on zero?:
      I tested this with following parameters successfully. Could you test if these parameters works for you also?
      Could you check that is this property really missing from some components?
      If you need to check the count only for the components that has the property you can add that into the upper filter in the same rule.
      • _c__ Offline
        _c__ Offline
        _c_
        wrote on last edited by _c_
        Hello, thank you for your answer.
        I can’t enter zero, the field is disabled.
        The rule I need is another, though: I need the rule to check for the existence of a number, any number, including zero, perhaps the 203 is not right.
        c
        • _c__ Offline
          _c__ Offline
          _c_
          Also trying a list of values doesn’t take zero:
          c
