  3. New Rulesets added and the previous checking results changed. why?
3 Posts 2 Posters 432 Views
    Pann MH
    Hi, I’m Pann and would you guys like to help me solve this problem👇 ?
    My checking result were changed after I added a new rule…
    There were NG results for slab and ceiling that has intersections with MEP.
    But when i added a new rule for Allow beam intersections, the previous NG results for slab and ceiling became all ok(passed) without changing any parameters.
    I put the pictures of my rules and parameters.
    These are the first results and its parameters.
    Below are the results after I added the new rule.
    I didn’t change the parameters.
    (the rule I added.)
    Can you guys help me ?
      Hello @Pann-MH!
      Are you by any chance using the “Check Selected” feature in your workflow? This feature is known to cause similar difficulties, outlined in this post, which we are addressing in the upcoming 9.12.0 release.
        Pann MH
        Hi Toni @tonigyllenberg
        Thanks for the reply.
        I was using the “Check Model” Feature and didn’t work out.
        I tried making new rulesets (with same properties) in new smc file and it was still the same.
        And then, I deleted the Property Value and added the same value again and it was ok.
        This one project is now good but I still don’t get the cause of the problem.
        Sincerely, Pann
