  3. Problem with the Map view
5 Posts 3 Posters 867 Views
    DoPay
    With the 9.12 version, I have the yellow dot but I don’t have the plan view.!
      DoPay
      wrote on last edited by DoPay
      Bonjour,
      With v.9.12.3 I still have the same problem with the navigation map. Do you think it’s a georeferencing problem?
      chrisC agroniA 2 Replies Last reply
        replied to DoPay on last edited by
        @dopay of course it is😉
          @dopay
          sorry to say, but the only thing that is correct in those coordinates is the “Z”.
          Many BIM guidelines enforce the usage of small coordinates.
            DoPay
            @chris For me the geolocation of the models imposes in Revit and in Archicad that the models are close to the points of origin of Softwares, but that it is the coordinates (Data) of the Reference Point of Localization in Archicad and the Base Point in Revit which are informed…
            Tell me if I am wrong.
            @agroni you said : "Sorry to say, but the only thing that is correct in these coordinates is the “Z”.
            Reluctantly I I tried to leave the buildings close to the X,Y = 0 coordinates and keep the elevation relative to sea level in Archicad and Revit, but even doing this the Solibri navigation map does not adapt itself to the Z of the project:
            Example 1: if I put myself at N02 in the map, the 3D view shows me the basement!
            Example 2: If I approach of N02 in the 3D view, the navigation map shows me the roof level rather than N02. Is this normal ?
            Question:
            Wouldn’t it be possible to manage in the Solibri parameters the insertion point of the IFCs files at (choice) :
            • coordinates 0,0,0, of Solibri, or
            • real coordinates of IFC
