  3. #234 - Component inside Component | Why is this not throwing an error?
1 Posts 1 Posters 267 Views
    Quick question related to #234
    Checking here if the Slab in this Space is 2mm < x < 100 mm away from the Side Surfaces from its Outer Components. Well, in this example here 3 sides are not meeting this requirement, but why is there no error just beacuse one side is ~5mm away? Did I forget here something, I thought this should work.
    On a double check, if all the sides are not within range than there is indeed an error.
