SOL/17/1.6
@jsn said in SOL/17/1.6:
You could probably use the excel export/import to speed up the setup workflow and just copy/paste the layer there if it’s the same? Regarding your wish, do you mean “any/*” of a discipline or how should it make sense in the end?
Thanks a lot for reply. I use the excel. I want just to compare the layer names with prescripted layer names from BEP. I dont want to prescribe specific “component type” to each layer. I simply wanted to write * as it is possible in second column. Report of this rule tells me if the layer is missing in model or missing in BEP. But know I have to develop which component can be in which layer.
Best regards,
Zdeněk -
@zdeněk said in SOL/17/1.6:
Well, this ain’t gonna work with that rule as it validates elements and not layers. Furthermore if you put an asterix then this …
… wouldn’t work either as you check all elements (which are on different layers I guess) at once and therefore you would kinda get a weird result as this rule just has been created for the opposite purpose.
However you could probably use a different rule to achieve what you want. E.g. check all the layers of all elements with #230 and if there is no match you are informed.
