  3. SOL/231/1.6 bug?
SOL/231/1.6 bug?
4 Posts 3 Posters 1.0k Views
    lraimo
    Hi
    Is this a bug of rule SOL/231/1.6 or I am using it wrong? When I use one row in Filter for Components to Compare everything is working, if I add second row I get no elements if I press button Set to Selection Basket. I am using different Classification properties.
    Elements will be in Selection Basket
    No elements in Selection Basket
    agroniA 1 Reply Last reply
      replied to lraimo on last edited by
      @lraimo
      I don’t have a direct answer for you here, but maybe a suggestion.
      This rule in my opinion is quite tricky. Therefore try to tweek the settings until you reach the desired result, either correct or wrong. Play with the Direction, the Quantifier and the Components to compare. There are some combinations that could be tried out.
      To create a rule with this SOL, I always do simulate a false/correct test. When I am sure that it works, I declare it as a success…
      • Y Offline
        Y Offline
        YasmineD
        @lraimo , when you filter elements you need to take into account that it filters the rules per rows in an ‘AND’ statement instead of ‘OR’ so what you’re saying is:
        1. select any component with certain properties in row 1
        2. starting from the selection you already made in row one, now you’ll filter this primary selection and filter that they also need to have the second filter row as a rule
        I hope I’ve made myself clear because it’s not so easy to explain. You can solve it though by using the exclude option
        First you select any without any rules/properties and then you exclude the ones you don’t want:
        https://solibri-community.force.com/know2/s/article/UUID-a90c2211-2dca-acf1-3055-4ebcc3b005ed
          lraimo
          @YasmineD I understand, but @Solibrians why does it filter the rules per rows in an “AND” statement? Other rules behave as “OR” statement.
          At the moment I do not see solution if I have to use 2 different classification.
