  3. Problem it doesnt show the Issue´s Element
3 Posts 2 Posters 543 Views
  • X Offline
    X Offline
    xeoware
    I would like to ask you if this has happened to you before.
    I created Issues in Solibri and then I exported them as BCF. When I look at the Issues in Revit, the BCF Manager does not show the element of the Issue, but the whole model.
    Does anyone know where I can find the problem or what am I doing wrong?
    HechtwieFischH 1 Reply Last reply
    • HechtwieFischH Offline
      HechtwieFisch
      replied to xeoware on last edited by
      @xeoware Hi for narrowing down the problem you could check
      1. in Solibri in the Tab “Komponenten” if there is only the relevant objects linked
      1. In BIMcollab which objects are linked to the Issue
      • X Offline
        X Offline
        xeoware
        Hello HechtwieFisch, thanks for your Reply.
        I tried again, with the same BCF file, and it worked. I don’t know what the problem was. Probably it got solved because I restarted Revit. who knows, but thanks.
