  3. Responsibilities and labels for multiple slides showing not showing the common values?
2 Posts 2 Posters 280 Views
    A) If I mark one slide …
    … I get the following values.
    B) If I mark another slide
    … I get this values as well as I have assigned them here as well.
    C) However if I mark them now at the same time, then I get this?
    Multi editing slides does not speed up if it has this irritating behaviour.
    • john.lippJ Offline
      john.lippJ Offline
      john.lipp
      Hi @JSN
      I reproduced this issue and sent it to R&D.
      If you multi-select a slide that has a label or responsibility set, that responsibility gets “Stuck” as being selected when you multi-select other slides, even across other presentations.
      I have found in limited testing, that you can workaround the issue and still multi-select slides to set responsibilities in the communication layout by carefully watching the Responsibilities and Label columns in the Issues view while you click the incorrectly displayed responsibilities and labels in the Issue Details.
