  3. Decision in coordination report
4 Posts 3 Posters 877 Views
  • Y Offline
    Y Offline
    YasmineD
    Hello everyone,
    Can somebody help me figure out how to add the components decision (Accepted ✔ , Rejected ❎ , …) to the coordination report that I’m making of my presentation ‘from checking results’?
    I need something like this to add to my excel template, but can’t seem to find what exactly:
    <SLIDE_ID>
    <SLIDE_NUMBER>
    <SLIDE_LOCATION>
    <SLIDE_TIME>
    <SLIDE_PICTURE>
    <SLIDE_COMMENT>
    <SLIDE_STATUS>
      replied to YasmineD on last edited by JSN
      @yasmined
      Does page 11 help you? Not sure if there is the possibility to tag the coordination status …
      https://society.solibri.com/assets/uploads/files/1632503912424-2021_08_coordination-report-templates.pdf
      Y 1 Reply Last reply
      • Y Offline
        Y Offline
        YasmineD
        @jsn , it does not, see it doesn’t give me anything for the component decision, which I understand on one hand because a slide does not always have components in them.
        Thank you though for looking into it!
        • john.lippJ Offline
          john.lippJ Offline
          john.lipp
          Hi @YasmineD
          I logged this as an enhancement to our development to add a <SLIDE_DECISION> keyword to coordination report templates.
          The best workaround I can suggest would be to sort by checking decision by dragging that column in the Issues view to the left and multi-select and mark those with the same checking decision to use the “Report Only Marked” option in the coordination report options.
          It would be a manual process, but you could then add the column and fill in the Accepted/Rejected manually and then combine the report to one.
