  3. Displaying model in PowerBi
31 Posts 11 Posters 15.7k Views
    Jack.Allason
    Mainly quantities, but a step even further a comparison of two models (overlaid) - similar to the comparison tool, but with quantities detailed as you click on items.
      So the easiest way probably is to just export ITO results into an Excel file and then import that into PowerBI.
        It would be great to visualize LOI and LOG data from Solibri in PowerBI. As other tools like tracer does…
          Nuno
          There are some 3D viewers for PowerBI like:
          • Tracer: https://apps.provingground.io/tracer/
          • EZPowerBI: https://ezpowerbi.wordpress.com/tag/ifc/
          chrisC 1 Reply Last reply
            Other tools that allow the visualization of models in PowerBI are
            Vcad https://www.bimservices.it/
            KG-dev https://kg-dev.be/project/3dbi-for-revit/
            I have personaly tested Tracer from ProvingGrounds. It is a very good tool to visualize models and interactive as you are requesting.
              replied to Nuno on last edited by chris
              @nuno Tracer has some problems with huge models.
              Another interesting tool is https://www.seve-up.com/
              Much faster than tracer, really good default data structure in powerBi. I like a lot 😊
                Thanx for the tip @chris. I will also give it a look.
                The price is a bit high thout (I think!). Do you use is so much in one or two projects (standard plan) during a month period?
                Sorry, we drifted a bit from Solibri with this Topic 😁
                  @agroni nothing is for free 😁 I only tried the free plan. I liked a lot…
                    3D Repo also started some developments by the beginning of this year.
                    https://3drepo.com/power-bi-custom-visual/
                    I like the workflow (they have a well-documented API that might nicely handle automated processes), but the viewer still lacks behind.
                      Hi. An upcoming Solibri version makes this directly possible without exporting any data to outside files or databases, so if you are interesting in testing it out, join the testing group https://society.solibri.com/topic/1194/upcoming-solibri-version-testers-wanted
                        @lasse-lindqvist said in Displaying model in PowerBi:
                        Makes what possible?
                          @jsn said in Displaying model in PowerBi:
                          It allows you to load a Solibri project file to PowerBI and visualize data such as classification results, ITO calculations and checking results.
                          The 3D data is available as well, but there also seems to be some PowerBI visualizer that work with IFC sources based on the links.Not sure how well they work in reality.
                          • Lauri LuomaL Offline
                            Lauri Luoma Solibrians
                            @Jack-Allason @chris @Nuno @agroni @Alexander-Joslyn @JSN
                            Here is a simple example of saving a model to a new file format (.solibri) with the new Solibri version (currently in alpha) and visualizing the classifications of the model in PowerBI:
                            As @lasse-lindqvist mentioned it is also possible to access other data in the models.
                            J N 2 Replies Last reply
                            6
                              @Lauri-Luoma
                              that looks very promising.
                              I assume that this .solibri database is readable in PowerBI and other queries could be generated.
                              Respectively, is the type of information in the .solibri file adaptable, meaning that we can decide what to export?
                                @Lauri-Luoma Great News! To have a Solibri 3D Viewer Visual directly in the PowerBI would be really great… 😊
                                  #18
                                  @agroni said in Displaying model in PowerBi:
                                  Will it blend, that is the question!
                                  Would be indeed good to know if there are custom visuals involved - as I assume there will most likely be one for the mentioned 3D view - and can the data be accessed as tables e.g. to create relationships and use it with other visuals? Anyhow, good to see that progress is made in that direction as well!
                                    Jack.Allason
                                    @lauri-luoma this looks interesting. How do I open the info in PowerBi? Is it still having to be exported into an excel, or is it straight from a solibri file?
                                      replied to Jack.Allason on last edited by
                                      @jack-allason said in Displaying model in PowerBi:
                                      PowerBI can read the Solibri file directly, without any need to export to Excel or other formats. You will need to import the Solibri file as an SQLite 3 database file as an ODBC datasource. More instructions on that can be found for example in https://www.biinsight.com/visualise-sqlite-data-in-power-bi/ but we will also provide more detailed instructions on how to work with Solibri files later.
                                        Nuno
                                        Hi @lasse-lindqvist
                                        It would be nice to see an example for this connection.
                                        I tried to follw the instructions in the site you refer. As path to the database I gave a solibri file. However I don’t get access to any table:
                                        I wounder about what I have missed, or if it is just possible with the export with Solibri API, or if it is possible with files save in the current version, or in the coming version Solibri 10…
                                        I’m looking forward to use this funcionality of Solibri. 🙂
                                        Regards
                                        Nuno
                                          Hi. It is only available in the upcoming unreleased version that is currently only available for alpha testers. Sadly I don’t have instructions on setting up the connection, as it does require installing some things for PowerBI and is not available out-of-the-box, but I hope we can have those out in the near future.
                                          M 1 Reply Last reply
