  3. Rules are not working anymore after Model Update - unless I copy them.
4 Posts 3 Posters 671 Views
    What is the reason why existing rules are not checking anymore after model update?
    This is my file before I update:
    After updating a model (almost identical, classifications are still working, …) and checking again the results dissapper and there is just … nothing in the active rules and checking process is finishing very quickly.
    However if i copy the ruleset it works (without changing anything) - needless to say that all my result connections are gone when I do this, so not really an option.
    Tried it a few times - not even closing and opening the ruleset helps me here, only if I copy or recreate the ruleset - it is everytime the same, what is going on here?!
    Harmen JorritsmaH 1 Reply Last reply
      manuel.furia Solibrians
      wrote on last edited by manuel.furia
      Hi!
      It’s difficult to debug this problem without logs. You could contact our Support ( https://help.solibri.com/hc/en-us/requests/new ), describe the problem and provide them with logs (and possibly the model that is causing the problem).
      Best Regards,
      Manuel Furia
        replied to manuel.furia on last edited by JSN
        @manuel-furia
        It is indeed difficult to detect the culprit and I am spending now most of the day trying to rescue my slides and find a workaround.
        What I’ve found out so far is that the subrules of a gatekeep are not working after I update any model in the file.
        If I copy the the rules and do not change anything they work, but fun fact: if I update the models again they won’t work either and i would have to repeat this all over again.
        Does this help you to recreate the problem? For now to complete the task in time I found a complicated classification workaround to pass by the gatekeepers but that can’t be the final solution. I will investigate this further and probably send sth in the other day if I find some time, but all signs indicate that there’s something mysterious going on with the gatekeepers.
        • Harmen JorritsmaH Offline
          @jsn
          Sometimes is works after you update the model, to open a classification settings and click OK.
          Than the rules thinks there are changes made and will check the new model good(more time)
