  3. Checking becomes unbearable
7 Posts 3 Posters 2.1k Views
    BIM1337
    I’m running some rulesets and Solibri slows down to a point where I cant even scroll through the results. It takes like 5 minutes to just being able to click something and then freezes for another 5 minutes when trying something else.
    Just using basic rules like: SOL/1/5.0, SOL/176/2.2, SOL/11/4.1.
    vmoptions has been set to use: 16384m.
    This is the error in the output log:
    10:52:22.346 [Checking] INFO c.s.s.p.c.actions.CheckDesignAction - Checking started
    10:52:49.908 [ForkJoinPool-1-worker-13] ERROR com.solibri.sae.greenox.Constraint - com.solibri.constraints.construction.ConstructionTypesFromAgreedListConstraint can’t find resource string for key: par.DEFAULT_VALUE
    11:11:04.997 [ForkJoinPool-1-worker-3] ERROR com.solibri.sae.greenox.Constraint - com.solibri.constraints.construction.GeneralInterferenceConstraint can’t find resource string for key: reportTable.DEFAULT_VALUE
    11:11:04.998 [ForkJoinPool-1-worker-3] ERROR com.solibri.sae.greenox.Constraint - com.solibri.constraints.construction.GeneralInterferenceConstraint can’t find resource string for key: reportTable.DEFAULT_VALUE
    11:11:05.696 [ForkJoinPool-1-worker-9] ERROR com.solibri.sae.greenox.Constraint - com.solibri.constraints.construction.GeneralInterferenceConstraint can’t find resource string for key: reportTable.DEFAULT_VALUE
    11:11:05.697 [ForkJoinPool-1-worker-9] ERROR com.solibri.sae.greenox.Constraint - com.solibri.constraints.construction.GeneralInterferenceConstraint can’t find resource string for key: reportTable.DEFAULT_VALUE
    11:11:08.055 [ForkJoinPool-1-worker-13] ERROR com.solibri.sae.greenox.Constraint - com.solibri.constraints.construction.GeneralInterferenceConstraint can’t find resource string for key: reportTable.DEFAULT_VALUE
    11:11:11.520 [Checking] INFO c.s.s.p.c.actions.CheckDesignAction - Checking ended
      Hi. You should check Windows Task manager and what it shows for your CPU consumption while the checking is in action. Then if the CPU usage is really high, also check your Performance settings under General and make sure you are not assigning too many threads there, if you are assigning more than the amount of CPUs your machine has, you will want to decrease the amount so that it leaves some available for other things than the checking.
        BIM1337
        Threads was set at 0.
        Tried different numbers that are possibile according to my cpu, yet it makes no difference in performance.
          Hi. In that case you need to send the .smc file to support so we can run the same checks and profile/debug the situation to see what is so CPU intensive in your particular case. It can be things such as single components with really complex geometry.
            BIM1337
            I’ve submitted the files to support, waiting for a response still.
            Will post when fixed.
            chrisC 1 Reply Last reply
              replied to BIM1337 on last edited by chris
              @BIM1337 result of this issue?
              B 1 Reply Last reply
                BIM1337
                @chris said in Checking becomes unbearable:
                After contacting Solibri Support they requested me to try running the check with the Solibri 10 Alpha version. This greatly improved the speed and the checking wasn’t unbearable anymore.
                They’d still investigate the model but haven’t given any updates on the issue. My guess is because it has a low priority, since the release of the new version is around the corner, and there, the issue is mostly fixed.
