  3. Help required - Schedule of quantities and Embodied Carbon
3 Posts 2 Posters 676 Views
    Rocket28
    Hi
    I am very very very new to Solibri, and have an assignment to complete. I can do the first part, but I am getting really stuck on how to complete a schedule of quantities and calculate the embodied carbon in the building. Is there any guidance documents or the like out there for me to look at? I cant find anything on the web. For clarity, the question is as follows:
    "*3.a) Create a schedule of quantities for materials listed in Appendix ‘B.’ You will need to use take-off tools in Solibri to tally volumes of material and calculate the embodied carbon. You will also need to create a 3D visualisation of the materials, showing the locations of each material, one-by-one, in 3D. Combine these slides into a presentation in Solibri. Analyse the Embodied Carbon of your design (using the CO2 numbers listed in Appendix ‘D’) for the selected materials.
    3.b) Re-deign your building and propose design changes that will reduce your carbon footprint by at least 10%. Create a second version your Schedule of Quantities & Carbon Visualisation saving them as new files.*"
    I am struggling on the above not only because I am net to the software, but as I am stuck at home due to COVID restrictions and I am unable to attend class in person. Whilst the video classes help, I am still stuck on how to do this so any help would be truely appreciated!
    For clarity, I have already designed a small, two storey commercial building in Revit, which includes parameters that will facilitate phase planning.
    Thanks again,
    Rod
    • hkringsKUBUSH Offline
      hkringsKUBUS
      Hi Rod,
      Here are some tips but the main tip is to try as much as possible.
      • Use the Solibri helpcenter for basic information
        Here is an article about understanding and creating an information Take-Off (which you need for you schedule): https://help.solibri.com/hc/en-us/sections/1500000632561-Quantity-and-Information-Takeoff
      • Play around with the columns in the ITO. What happens when adding a column, changing the sequence of the columns and turning the option “grouping” on/off for a column.
      • Any information in a property set (these are the tabs in the info view with grey/blue header tekst) can be added to an ITO by choosing the column type “property set”.
      • Consider using a classification to “group” your materials how you like them (https://help.solibri.com/hc/en-us/sections/1500000614901-Classification)
      • In the helpcenter you can also find information about making a presentation from an Information Take-Off
      Good luck.
        Rocket28
        Thanks so much for the reply! Will have a good look and let you know if I run into any more issues. Thanks again.
