  3. different unit
different unit
7 Posts 3 Posters 1.1k Views
    tina.ng
    wrote on last edited by tina.ng
    why the settings is in meter but the result is in ft?
      Hi. The description is static text after it has been generated. So changing settings afterwards does not update it. But rerunning checking after the units have changed should update the description to use the new units.
        tina.ng
        Hi, thanks for the answer but the situation remains the same after rerunning the checking after changing the units…
          Patrick
          wrote on last edited by Patrick
          Have you tried closing and then opening up the model again? That usually solves it for me in ITOs.
            tina.ng
            yes but it doesn’t work.
              replied to tina.ng on last edited by
              @tina-ng said in different unit:
              This does sound weird if the description otherwise updates, but the unit stays the same old one. I believe most likely what is happening is that the result is not being regenerated, either because the rule is not really run or something else. You can also try moving the rule parameter and changing them back to make sure the rule is rerun.
              T 1 Reply Last reply
                tina.ng
                @lasse-lindqvist Yes. You are right. Thanks so much!
