  3. Control As-builts
Control As-builts
6 Posts 2 Posters 1.2k Views
  • I Offline
    I Offline
    IFC GHOST
    Hello Solibrians,
    I want to control as builts 2D plans using Solibri, is there anyway to do it ?
    Regards.
      Sander E
      What I do is to set a PDF as drawing in Solibri.
      Then i do a visual check if its the same.
      • I Offline
        I Offline
        IFC GHOST
        Hello @sander-Eikelboom,
        Thank you for your reply.
        How do you import and position the drawings on the right place, floor… ?
        I thought it is impossible with Solibri.
        Regards.
          Sander E
          Hi IFC Ghost,
          See the immage below. I hope this will help.
          • I Offline
            I Offline
            IFC GHOST
            @sander-Eikelboom
            Yes it is clear, thank you.
            How do you import pdf drawings ?
            Is there any way to do it automaticaly by creating a rule which can control lags between the drawings imported and IFC wall bases ?
            Regards.
              Sander E
              You’re welcome.
              You can add pdf’s by selecting ‘add models’.
              As far as I know there is no way to creating rules for pdf files.
