  3. JavaScript error
JavaScript error
13 Posts 8 Posters 3.8k Views
    Hi. There is one known bug where starting Solibri in offline mode fails. And unrelated to that some Javascript functions fail to compute but that shouldn’t happen at startup. The Javascript bug is described also here: https://society.solibri.com/topic/415/problems-with-javascript-and-solibri-9-10-4-13/2 in the Solibri Developer Platform subforum.
    B 1 Reply Last reply
      b.huijskes
      @lasse-lindqvist
      I’ll take that into consideration, however all systems are connected to the internet and as such should not be in offline mode, right?
      Also, the error reads something different than what is posted by @adrianobalduino . Perhaps it is something else?
        replied to b.huijskes on last edited by
        @b-huijskes said in JavaScript error:
        @lasse-lindqvist
        The similar crashing behaviour might be triggered with a borrowed license perhaps. Otherwise full logs of the software would help solve this.
          We are experiencing the same error on multiple machines in the latest update.
          This is an error that we haven’t seen before on earlier versions.
          The computers are connected to the internet, and we don’t use offline/borrowed licenses.
            @Solibrians
            I have now about 7 individual people who are getting this error!
            Please fix this!
            Jeroen
              @Ricardo said in JavaScript error:
              Hi. Could you send the logs related to this to [email protected] or [email protected]?
                @lasse-lindqvist
                Where can i find log files?
                It is not happening on my computer but if you let me know where I can find log files i will try to get one.
                KR
                Jeroen
                  The logs can be found from the installation folder under subfolder “log”. Usually this is C:\Program Files\Solibri\SOLIBRI\log
                    replied to lasse.lindqvist on last edited by Matti
                    Solibri 9.10.5 Hotfix is released. The JavaScript problem is fixed.
                      bbeata
                      Hi everyone,
                      it’s look like we have the same java errors problem but with a year difference and I have no idea how to fix it. It’s already happened 3 times and it’s make really crazy when you loose a month or more job. Have anybody had the same problem since a month or three, or it’s just by us? Did you fix it and how? Thanks a lot in advance!
                      %(#000000)[%(#373737)[Anwendungs-Build-Nummer: 9.12.8.33
                      Das Modell wurde mit einem Build mit der Nummer gespeichert: ?
                      java.io.EOFException: Unexpected end of ZLIB input stream
                      at java.base/java.util.zip.InflaterInputStream.fill(InflaterInputStream.java:244)
                      at java.base/java.util.zip.InflaterInputStream.read(InflaterInputStream.java:158)
                      at java.base/java.util.zip.ZipInputStream.read(ZipInputStream.java:196)
                      at java.base/java.io.BufferedInputStream.fill(BufferedInputStream.java:244)
                      at java.base/java.io.BufferedInputStream.read1(BufferedInputStream.java:284)
                      at java.base/java.io.BufferedInputStream.read(BufferedInputStream.java:343)
                      at com.solibri.sae.redox.ProgressMonitorInputStream.read(Unknown Source)
                      at java.base/java.io.ObjectInputStream$PeekInputStream.read(ObjectInputStream.java:2842)
                      at java.base/java.io.ObjectInputStream$PeekInputStream.readFully(ObjectInputStream.java:2858)
                      at java.base/java.io.ObjectInputStream$BlockDataInputStream.readFloats(ObjectInputStream.java:3533)
                      at java.base/java.io.ObjectInputStream.readArray(ObjectInputStream.java:2097)
                      at java.base/java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1677)
                      at java.base/java.io.ObjectInputStream.readUnshared(ObjectInputStream.java:590)
                      at com.solibri.sae.geometry.GEntity.a(Unknown Source)
                      at com.solibri.sae.geometry.GEntity.readObject(Unknown Source)
                      at jdk.internal.reflect.GeneratedMethodAccessor33.invoke(Unknown Source)
                      at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
                      at java.base/java.lang.reflect.Method.invoke(Method.java:567)
                      at java.base/java.io.ObjectStreamClass.invokeReadObject(ObjectStreamClass.java:1224)
                      at java.base/java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:2378)
                      at java.base/java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:2212)
                      at java.base/java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1689)
                      at java.base/java.io.ObjectInputStream.readArray(ObjectInputStream.java:2112)
                      at java.base/java.io.ObjectInputStream$FieldValues.<init>(ObjectInputStream.java:2554)
                      at java.base/java.io.ObjectInputStream.readFields(ObjectInputStream.java:677)
                      at java.base/java.util.Vector.readObject(Vector.java:1158)
                      at java.base/jdk.internal.reflect.GeneratedMethodAccessor32.invoke(Unknown Source)
                      at com.solibri.sae.redox.Property.readObject(Unknown Source)
                      at jdk.internal.reflect.GeneratedMethodAccessor27.invoke(Unknown Source)
                      at java.base/java.io.ObjectInputStream.defaultReadObject(ObjectInputStream.java:633)
                      at com.solibri.sae.redox.Model$ClassNode.readObject(Unknown Source)
                      at jdk.internal.reflect.GeneratedMethodAccessor53.invoke(Unknown Source)
                      at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
                      at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:78)
                      at com.solibri.sae.redox.Model.readObject(Unknown Source)
                      at java.base/java.io.ObjectInputStream.readObject(ObjectInputStream.java:495)
                      at java.base/java.io.ObjectInputStream.readObject(ObjectInputStream.java:453)
                      at com.solibri.sae.redox.Model.b(Unknown Source)
                      at com.solibri.sae.redox.Model.openModel(Unknown Source)
                      at com.solibri.saf.plugins.modelhandling.actions.OpenModelAction.a(Unknown Source)
                      at com.solibri.saf.plugins.modelhandling.actions.OpenModelAction.openModel(Unknown Source)
                      at com.solibri.modelchecker.core.ModelChecker.c(Unknown Source)
                      at com.solibri.modelchecker.core.ModelChecker.d(Unknown Source)
                      at java.base/java.lang.Thread.run(Thread.java:831)]]
                        @bbeata said in JavaScript error:
                        That sounds actually more like a corrupt file due to saving issues.
                        Check your backup files!
                        https://society.solibri.com/topic/847/application-build-error?_=1643630446648
