  3. Displaying model in PowerBi
31 Posts 11 Posters 12.9k Views
    @Lauri-Luoma Great News! To have a Solibri 3D Viewer Visual directly in the PowerBI would be really great… 😊
      #18
      @agroni said in Displaying model in PowerBi:
      I assume that this .solibri database is readable in PowerBI and other queries could be generated.
      Respectively, is the type of information in the .solibri file adaptable, meaning that we can decide what to export?
      Will it blend, that is the question!
      Would be indeed good to know if there are custom visuals involved - as I assume there will most likely be one for the mentioned 3D view - and can the data be accessed as tables e.g. to create relationships and use it with other visuals? Anyhow, good to see that progress is made in that direction as well!
        Jack.Allason
        @lauri-luoma this looks interesting. How do I open the info in PowerBi? Is it still having to be exported into an excel, or is it straight from a solibri file?
          replied to Jack.Allason on last edited by
          @jack-allason said in Displaying model in PowerBi:
          PowerBI can read the Solibri file directly, without any need to export to Excel or other formats. You will need to import the Solibri file as an SQLite 3 database file as an ODBC datasource. More instructions on that can be found for example in https://www.biinsight.com/visualise-sqlite-data-in-power-bi/ but we will also provide more detailed instructions on how to work with Solibri files later.
            Nuno
            Hi @lasse-lindqvist
            It would be nice to see an example for this connection.
            I tried to follw the instructions in the site you refer. As path to the database I gave a solibri file. However I don’t get access to any table:
            I wounder about what I have missed, or if it is just possible with the export with Solibri API, or if it is possible with files save in the current version, or in the coming version Solibri 10…
            I’m looking forward to use this funcionality of Solibri. 🙂
            Regards
            Nuno
              Hi. It is only available in the upcoming unreleased version that is currently only available for alpha testers. Sadly I don’t have instructions on setting up the connection, as it does require installing some things for PowerBI and is not available out-of-the-box, but I hope we can have those out in the near future.
              M 1 Reply Last reply
                Nuno
                #23
                @Lauri-Luoma Hi!
                I find this functionality very usefull 🙂
                Do you have a map with the relations between the tables or some tips about it that you can share?
                Regards
                Nuno
                  replied to Nuno on last edited by
                  @Nuno said in Displaying model in PowerBi:
                  @Lauri-Luoma Hi!
                  Regards
                  Nuno
                  Basic tables:
                  COMPONENT holds basic info about components
                  SLIDE, PRESENTATION, PRESENTATION_SLIDE about presentations and slides
                  VIEWPOINT, VISUALIZATION, SNAPSHOT the picture related stuff about slides.
                  COMPONENT_SOMESUBCLASS contains some subclass data about certain components. Connects to COMPONENT via ID field.
                  RELATIONS_XYZ contains the IFC-relations for components
                  STRING table contains deduplicated texts. Many tables reference this via the ROWID column. For example COMPONENT_SITE has NUMBER_STRINGS_ROWID column.
                  COMPONENT-COMPONENT_PROPERTYSET-PROPERTYSET-PROPERTYSET_PROPERTY-PROPERTY can be joined to find all properties from IFC propertysets.
                  “DB Browser for SQLite” is useful GUI application for browsing what is in the file.
                    Nuno
                    wrote on last edited by Nuno
                    #25
                    Thanks Lasse!
                    Do you also know the sequence of tables for ITOs and Classifications?
                    Regards
                    Nuno
                      #26
                      Thanks Lasse!
                      Regards
                      Nuno
                      CLASSIFICATION
                      ITO
                      These contain XML in them.
                      CLASSIFICATION_RESULT
                      This has a column pointing to INTEGERLIST table and the list of integerers is the ID-fields of the components in question.
                      ITO_RESULT-ITOROW-ITOCELL
                      ITOROW represents one row in the ITO results table and ITOCELL one cell (think of Excel cells). ITOCELL might reference other tables, such as MATERIAL table in case the cell represents a color/material.
                        Nuno
                        @lasse-lindqvist said in Displaying model in PowerBi:
                        Hi Lasse,
                        Can you be more precise, please.
                        CLASSIFICATION_RESULT as a field COMPONENT_SET_SET_ID. Is this one that connects to INTEGERLIST (I supouse to LISTID field)? Then I would supouse the VALUE field from INTEGERLIST would connect to ID in COMPONENT table. Is this what you mean?
                        There is another table COMPONENT_SET. Is this needed?
                        I still don’t get the total components for each classification…
                        Regards
                        Nuno
                          #28
                          Hi Lasse,
                          Regards
                          Nuno
                          It uses INTEGERLIST table only. I hope we can get rid of the COMPONENT_SET table before the release. It is used in one place for grids/gridaxes.
                            mderitti
                            #29
                            @lasse-lindqvist hi!
                            Could you please explain how can I try this unreleased version?
                            I really need to try this connection with powerBI
                            • paultonerP Offline
                              paultonerP Offline
                              paultoner
                              Yeah, the process seems to have advanced in 2-3 years. No clear templates provided, processes, or add-ins etc. BIM Collab have released a template and add-in for PowerBI. Can Solibri pick up speed on this?
                                SamuelAB
                                wrote on last edited by SamuelAB
                                #31
                                As a BIM and PowerBI nerd, I would say that the best way to integrate large Revit/IFC models into PowerBI is through VIM AEC, the company I work for. We are looking forward to Solibri making their data available to PowerBI so that we can showcase an integration and release templates for users.
                                Check us out here at vimaec.com
