  3. Relations, Filter by relation, Rule 231
3 Posts 2 Posters 704 Views
  • I Offline
    I Offline
    Ilona C.T.
    Hi Solibrians,
    I would like to check certain windows/doors according to the space they are related to. I try to extract the elements I need to check using 231 as a gatekeeper rule, without any success. I m not sure whether it’s even possible or not.
    Since classification does not allow relations, I have a manual workaround to select certain objects related. But I need a solution totally automatized.
    Could you help please whether there is a rule or automatized workaround to filter elements according to relations?
    Thanks in advance
    Ilona
    • john.lippJ Offline
      john.lippJ Offline
      john.lipp
      Hi @Ilona-C-T
      Here is an example of checking Office Doors that uses Rule 231 to send Doors that have a nearest space with spaces named “office” to have further checks in sub rules:
      Solibri Building_Office Doors.smc
      The 231 Gatekeeper checks the door has at least 1 space that has the name office and sends those that pass the check to the sub rules of the gatekeeper:
      Also related, if you want to find distances of components in the same space, the component distance rule has a specifically to set for that:
      https://society.solibri.com/topic/1983/how-can-i-find-distance-between-components-within-a-space/2?_=1661287948197
      If you still have problems, can you upload an example?
      • I Offline
        I Offline
        Ilona C.T.
        Hi @john-lipp!
        Thank you very much for the explanation and for sending the .smc with the exact settings.
        I tested it and it seems working! I am more than happy 🙂
        Many thanks!
        Have a great day!
        Ilona
