  3. Small components and SOL/234/1.2 issue
234small objects
2 Posts 2 Posters 682 Views
    KimArndt
    Hey,
    I am having some issues with checking consistency of to models with small electrical fixtures.
    I am using the rule SOL/234/1.2 and checking for both orphaned components and checking protrusion i any direction with a max value of 2mm.
    However, when checking small components on small components (50x50x10mm) no protrusion is registred and ALL small components in both models are reported as orphaned.
    A small component is able to register protrusion on a larger object.
    After some testing, I found the limit for when this rule is working, and concluded that if a object have a volume over 100.000 mm³ and more than 10 mm of thickness the rule functions properly.
    Is this a known limitation of the rule or am I doing something wrong with my rule parameters?
    Is there a way to work around this, maybe by using another rule?
    Any input is appreciated.
    • K KimArndt referenced this topic on
      mkoolwaaij
      I have the same problem at the moment. This rule used to work for me, but the only result I’m getting now is: “No Inner Components” and “Orphan Inner Components”.
      There are some visually present issues, but I’m unable to get these in my Results by tweaking the Parameters…
      Could there be a bug?
