  3. Is it possible to determine element RGB color with Solibri?
8 Posts 3 Posters 1.7k Views
    lraimo
    Currently the only method I know is to read it from ifc
    #79=IFCCOLOURRGB($,0.000000,1.000000,1.000000);
      lraimo
      Is it possible?
        Hi. It depends a lot on what you mean by the color.
        The Java API does allow access to the component materials (https://solibri.github.io/Developer-Platform/9.12.4/javadoc/com/solibri/smc/api/model/Component.html#getMaterials())
        which corresponds to the IfcMaterial (http://standards.buildingsmart.org/IFC/RELEASE/IFC2x3/FINAL/HTML/ifcmaterialresource/lexical/ifcmaterial.htm) but that only has a name, not color.
        In the Solibri settings there is the possibility to choose what colors are used in the UI for different component. See Settings - Discipline and Color Map. These colors can be completely different from what the IFC determines as colors.
        Based on discussion here https://forums.buildingsmart.org/t/where-and-how-will-my-colors-be-saved-in-ifc/1806 it seems that colors in IFC are defined in quite many different ways.
        L 1 Reply Last reply
          lraimo
          I am looking for color that comes from this line
          So this line is ACAD 4 (Red 0, Green 255, Blue 255)
          B 1 Reply Last reply
            b.huijskes
            replied to lraimo on last edited by b.huijskes
            @lraimo I did some research about Materials and colours a while back. I am not sure if this will help you, but I can post my findings here. Although the text is in Dutch, you should still be able to read most of the images.
            In short: the DataType for colours is an IfcNormalisedRatioMeasure, meaning its value will be between 0 and 1, instead of between 0 and 255 you might be used to for standard RGB.
            To my knowledge, there are only a few Predefined colours within IFC:
            - Black (0 / 0 / 0)
            - Red (1.0 / 0 / 0)
            - Green (0 / 1.0 / 0)
            - Blue (0 / 0 / 1.0)
            - Yellow (1.0 / 1.0 / 0)
            - Magenta (1.0 / 0 / 1.0)
            - Cyan (0 / 1.0 / 1.0)
            - White (1.0 / 1.0 / 1.0)
            So even if it were possible to view these values in Solibri through the API, I think it would be tedious to find and translate all the possible values to AutoCAD colours.
            You can find the rest of my findings here: IfcMaterial.pdf
            If you find any mistakes I made, please let me know. I’m always curious to learn more about IFC.
              lraimo
              replied to b.huijskes on last edited by
              @b-huijskes
              Thanks for the material. Google translate helped to understand it.
              I would only need the RGB color assigned to component.
              For example this value
              From there I could calculate the ACAD color by multiplying them by 255 and using some Excel formulas.
              ACAD colors in RGB https://gohtx.com/acadcolors.php
                lraimo
                @lasse-lindqvist
                These elements do not have material (no Material tab in Solibri) but somehow all ifc viewer will show the same color.
                How does Solibri decides what color it will show the element? And is it possible to get this information using API?
                I can send example ifc or smc model if this would help
                  lraimo
                  @Solibrians
                  Is there any way to determine element RGB color with Solibri?
