NullPointerException
Hi everyone,
As mentioned before, I’m a complete beginner, so any advice is greatly appreciated.
I wrote a simple rule:
package com.solibri.rule; import java.text.MessageFormat; import java.util.Collection; import java.util.Collections; import com.solibri.smc.api.checking.IntParameter; import com.solibri.smc.api.checking.OneByOneRule; import com.solibri.smc.api.checking.Result; import com.solibri.smc.api.checking.ResultFactory; import com.solibri.smc.api.checking.RuleParameters; import com.solibri.smc.api.checking.StringParameter; import com.solibri.smc.api.model.Component; import com.solibri.smc.api.model.components.Space; import com.solibri.smc.api.model.components.Window; public class NumberOfWindowsInSpace2 extends OneByOneRule { private final RuleParameters params = RuleParameters.of(this); final IntParameter minimumAmountOfWindows = params.createInt("MinAmount"); final StringParameter resultNameStringParameter = params.createString("ResultName"); @Override public Collection<Result> check(Component component, ResultFactory resultFactory) { if (!(component instanceof Space)) { return null; } Space space = (Space) component; Collection<Window> windows = space.getWindows(); int amountOfWindows = windows.size(); int minimumAllowedAmount = minimumAmountOfWindows.getValue(); if (amountOfWindows >= minimumAllowedAmount) { return Collections.emptyList(); } String resultName = resultNameStringParameter.getValue(); String resultDescription = MessageFormat .format("The amount of windows in space {0} is less than allowed.", component.getName()); Result result = resultFactory.create(resultName, resultDescription); return Collections.singleton(result); } }But I keep getting the same error in Solibri:
Please send this error message and application information to [email protected] (see File->Help). Error Message: java.lang.NullPointerException: Cannot invoke "java.util.Collection.isEmpty()" because " " is null at com.solibri.smc.api.checking.OneByOneRule.a(Unknown Source) at java.basejava.lang.Iterable.forEach(Iterable.java:75) at com.solibri.smc.api.checking.OneByOneRule.check(Unknown Source) at com.solibri.saf.plugins.checkingplugin.rule.RuleSerializedState.check(Unknown Source) at com.solibri.sae.greenox.Constraint.d(Unknown Source) at com.solibri.sae.greenox.Constraint.runCheck(Unknown Source) at com.solibri.saf.plugins.checkingplugin.ui.CheckingViewPanel$CheckTask.compute(Unknown Source) at com.solibri.saf.plugins.checkingplugin.ui.CheckingViewPanel$CheckTask.compute(Unknown Source) at java.base/java.util.concurrent.RecursiveTask.exec(RecursiveTask.java:95) at java.base/java.util.concurrent.ForkJoinTask.doExec(ForkJoinTask.java:290) at java.base/java.util.concurrent.ForkJoinPool$WorkQueue.topLevelExec(ForkJoinPool.java:1016) at java.base/java.util.concurrent.ForkJoinPool.scan(ForkJoinPool.java:1665) at java.base/java.util.concurrent.ForkJoinPool.runWorker(ForkJoinPool.java:1598) at java.base/java.util.concurrent.ForkJoinWorkerThread.run(ForkJoinWorkerThread.java:183)After model checking. Could anyone explain what’s wrong with the code? Thanks!
@paulinasta said in NullPointerException:
if (!(component instanceof Space)) { return null; }I guess this is making problems downstream.
You may want to return an empty list instead of null (like you do whenamountOfWindows >= minimumAllowedAmount). The code that calls the OneByOneRule.check method tries to iterate over the result, with null that fails as you see.
