  3. Rule 230 fails on filtering floors?
4 Posts 3 Posters 974 Views
  • _c__ Offline
    _c__ Offline
    _c_
    I am trying to use the rule 230 as gatekeeper for performing rules floor by floor, but the filter seems to get lost continuously.
    The purpose is to achieve 1 ruleset for each floor = 1 presentation for floor. We have an agreement to check floorwise, which is apparently extremely hard to achieve. I don’t want to use sections or filters on the whole bulk of issues for a number of reasons, not last that we are trying to use Autorun and at the same time limit the issue slides.
    c
      replied to _c_ on last edited by
      @_c_ said in Rule 230 fails on filtering floors?:
      Solibri has an open problem in saving and opening floor based filters when using “One Of” or “None Of” operators.
      As workaround use text based operators like: Matches or Matches Case. In case you need many to match, classification might be needed to be used and filtering based on the classification.
      • _c__ Offline
        _c__ Offline
        _c_
        Thank you!!!
        You have no idea how much time I invested into this.
        c
        • HamzalaalaouiH Offline
          Hamzalaalaoui
          I know am late to this but why can’t you use classification to define the floor you want to check and place it in selection basket so that in the checking view you can check only selection ?
