  3. the Project Base Point
2 Posts 2 Posters 812 Views
  • K Offline
    K Offline
    karouite
    SOS
    Hello sollibrians,
    Is there any way to control the project base point ?
    Regards,
    • john.lippJ Offline
      john.lippJ Offline
      john.lipp
      This should be able to be set in the “Coordinate Base” setting of the IFC Export Setup in the later versions of Revit. In the earlier versions, the IFC export was always set to survey point (shared coordinates).
      https://help.autodesk.com/view/RVT/2022/ENU/?guid=GUID-E029E3AD-1639-4446-A935-C9796BC34C95
      If things aren’t lining up, you may need to publish or acquire coordinates in your project.
      You also are able to move a model in Solibri by right-clicking it in the Model Tree and clicking Move or Rotate Models: https://help.solibri.com/hc/en-us/articles/1500006891481-Moving-and-Rotating-Models
