  3. Solibri and DWG Files
14 Posts 9 Posters 5.2k Views
    Hi. The DWG importer we use is from 2014, so this is somewhat expected currently. I would recommend using IFC if possible.
      BIM1337
      Same here DWG’s never load in, now I know why.
      I always add PDF files instead.
      • D Offline
        D Offline
        dothedew
        I do try to load IFC files, but some trades can’t export to IFC and send me a DWG file; usually sprinkler contractors.
        I think I have been very patient waiting 7 years for some sort of DWG support.
        L 1 Reply Last reply
          replied to dothedew on last edited by
          @dothedew said in Solibri and DWG Files:
          Part of the problem is that the DWG is not an open file format, but undocumented and proprietary. While it is possible to achieve some level of reading capabilities for such files, it makes it unnecessarily hard. Especially being able to read different versions of such files.
          • paola bronzoP Offline
            paola bronzo
            Hi @Solibrians
            are there any improvements regarding dwg import? Solibri still doesn’t seem to support the latest versions of Autocad but only the 2013 (as it is written here https://www.solibri.com/learn/working-with-auto-cad-and-smc).
            Thanks
            Paola
            • david.weltsD Offline
              david.welts
              Hi @paola-bronzo,
              DWG support has been an issue for us for a while, however we are currently discussing how to improve it so hopefully can update you soon with our plan.
                lraimo
                @Solibrians
                Is there any update?
                Would like to get 2D DWG supported for Solibri
                  @lraimo Solibri supports PDFs. Could you convert your drawings to PDF?
                    lraimo
                    Yes, but PDFs in Solibri are quite slow and you have to manually align them
                    • BvanDalsumB Offline
                      BvanDalsumB Offline
                      BvanDalsum
                      Any updates? we use PDF but quality is very poor. like to use DWG as an alternative
                        Hello all!
                        Yes indeed we do! Improving 2D workflows is on our roadmap for Q3 this year. Perhaps this is a good chance to understand in addition to DWG improvements, are there other 2D workflow improvements that could be beneficial to you? A few we have on the list already:
                        • Displaying PDFs as floorplans on the Navigation map
                        • Improving the basic Navigation map to be more descriptive
                        • Improving DWG support
                        Looking forward to your input!
                        Toni
                          lraimo
                          2D DWG support and should able to hide/show DWG layers and save those settings.
                          Show DWG changes between versions
                          Able to automatically load older versions of DWG files.
                            Hello all!
                            We are beginning to develop the improvements for DWG support. One thing which would certainly help, would be to test against actual customer models. Would anyone here have models that could be shared (only within our development team for development and testing purposes)? If so, please reach out to me at:
                            [email protected]
                            Toni
