  3. Numeric Sorting in ITO?
4 Posts 2 Posters 621 Views
    What might be the best option to sort rows by their numeric values and not from A-Z?
      replied to JSN on last edited by Ricardo
      @jsn The column that is on the left side of the table gets sorted. So you could try to move this column to the left if it’s not there and then sort it.
        replied to Ricardo on last edited by JSN
        @ricardo
        Right, that is of course correct that the first column takes the lead on the first sort level, - also for values, but on a second level (for the other columns) it is only possible to sort from A-Z but not in a numeric order.
        Edit: just realized that it does work also on the second position but not on the third. Not sure if this is due that the next column contains not values but labels or if this just works for the first two columns.
        Ok seems like it works as long as there are just value columns used and not e.g. text columns in between.
          @jsn said in Numeric Sorting in ITO?:
          @ricardo
          Yeah, I guess it’s not possible but only for the first…
          Maybe one for the feature requests?
