  3. SOL 222 - Gatekeeper in "target Components" not working
3 Posts 3 Posters 660 Views
  • marchiM Offline
    marchiM Offline
    marchi
    Hi there,
    if somebody had a similar experience and how to solve this matter:
    I need an elaborate Checking Routine, which combines 3 Rules, all with the simple goal, to check if space boundaries of ceratin spaces have certain properties - and I need to check the space boundaries of all of the adjacent spaces (based on space classifications).
    1. I filter all space boundary components for later checking and the space with the desired classification, with SOL 230 (works OK)
    2. Gatekeeper with only passed Components (works OK)
    3. SOL 222 to check which of the passed Components are “touching” the passed spaces with the classification. (PROBLEM: Gatekeeper does not apply for “target Components” )
    • I have noticed that not only components that should have been passed, but also unpassed are checked under “target comp.”
    1. Gatekeeper with only failed Components (works OK)
    2. check space boundary components for properties, with SOL 230 (works OK)
    Example:
    00. we have classified spaces: “blue” (Space A1, A2) and “yellow”(Space B1, B2)
    1. filter all components and spaces with the desired classification, with SOL 230 (works OK)
      SOL 222 to check which of the passed Components are “touching” the passed spaces with the classification. (PROBLEM: Gatekeeper does not apply for “target Components” )BIM BUG 03.jpg
    PS. I cannot filter the desired spaces with SOL 222, as this is only a small view of the larger workflow which s depicted here.
    are there any other options that I am missing?
    here is the file:
    BIM BUG - Gatekeeper.smc
      @marchi said in SOL 222 - Gatekeeper in "target Components" not working:
      Did you find a workaround in the end? I am facing similiar issues when multiple gatekeepers are combined it’s very tricky to get what you want and you have to spin your head around multiple times …
      • Harmen JorritsmaH Offline
        Harmen Jorritsma
        I had a simalar issue.
        The support in my case say that only the left side of Some rulesets react with the Gatekeeper.
        It would be great to have a list of the rulesets witch only reacts with de lefrt columns
        Harmen Jorritsma
