  3. Check selected (but only specific rules?)
11 Posts 4 Posters 2.2k Views
    A bit of context first:
    In need a comprehensive report for all kind of rules.
    Some rules are applied on the whole model (e.g. checking for collisions), others should only check the elements with a special status e.g. “New”.
    So, sure Classifications/Component Filter is the way to go, but I have a big ruleset here where it would be very cumbersome to modify hundreds of rules for LOI: Not really an option.
    So, let’s use a Gatekeeper … mhm, somehow not working with rule 9/203/230* I think it’s a known issue but I will try to get some results here though. It’s just another Solibri thing where much time is lost to trace back the issue to finally realize that it simply does not work. Furthermore it leads to a strange issue where at some point rules stop to be checked no matter what I do. I think it’s been reported here some times ago as well. All in all, a main gatekeeper would be nice but: Unfortunately not an option.
    So for the sake of the moment to complete this task my workaround now is to 1. check the whole model and export the first report and then 2. check only selected (the “new” elements) and export the report again. Finally the reports are mereged manually by me so that the numbers are correct. Not a good solution, but it does the job.
    Christmas wish #1: Please fix the gatekeeper issues!!!
    Christmas idea #2: Wouldn’t it be worth the thought to add another/two more option to also only “Check Selected Rule on whole Model” / “Check Selected Rule with Selection Basket”
    It’s not just this workaround scenario where this might be very useful and timesaving but also in other situations. I think the only way to achieve this currently is to disable the other rules but I try to avoid that acutally because it “feels” not right.
    *9 has no “Any”
    *203 and 230 don’t reflect the correct numbers
    *moreover not the same ruleset hierchy in the exported reports given as well
      @JSN said in Check selected (but only specific rules?):
      What about this one?
      If I just want to re-run checking on a large set because of minor changes it takes time.
      Disabling all the other rule is not really an option because when you make whole folders active again it also activates rules which should remain disabled.
      So for the sake of testing, developing and speeding up minor checking checking routines consider that thought - is there any reason which argues against the possibility to just “Check selected ruleset” or right-click and check rule?
        Another year’s almost over and I could not resist reaffirming my christmas wish(es) …
        🎶 Last Christmas, I wished on a star,
        To Solibri developers, near and far.
        I asked for a feature, just a small plea,
        But alas, no response, not under the tree. 🎶
        🎶 This Christmas, I’ll sing it again,
        Hoping for options, just a few when,
        Checking my rules, oh developers, please,
        Add to the menu, bring joy and ease. 🎶
        🎶 Once bitten, twice shy, but not giving in,
        A wish for Solibri, let the coding begin.
        “Check Selected Rule on whole Model,” I say,
        Or “Check Selected Rule with Selection Basket” at play. 🎶
        🎶 This Christmas, my wish is still clear,
        To Solibri developers, lend me your ear.
        A response or feature, a gift just for me,
        In the world of BIM, oh can’t you see? 🎶
        🎶 In the Society, where wishes are made,
        I’m singing my heart out, not asking to trade.
        A jingle for Solibri, a dance and a song,
        Come on developers, let’s all get along! 🎶
        🎶 This Christmas, the third time around,
        Hoping for feedback, on festive ground.
        A rule-checking present, oh won’t you impart,
        Solibri devs, it’s time to warm my heart. 🎶
        🎶 Last Christmas, I asked with glee,
        This Christmas, bring joy to me.
        Solibri Society, let’s unite,
        For a feature so grand, shining bright! 🎶
        • Alex.JA Offline
          Alex.JA Offline
          Alex.J
          Fully agree with you that this feature would be very helpful. I had also communicated this idea to Solibri somewhere…
          A step further, we might need rule presets (selections of rules to be checked…)
          • Sini AaltoS Offline
            Sini AaltoS Offline
            Sini Aalto
            Thanks @JSN for making our day on Friday! 😄 And thank you for reminding us about this improvement, even though unfortunately we can’t still give any ETA for that. But we’ll take that into account in future feature prioritization.
              I can’t emphasize enough how handy this feature requests would be. Very often classifications need to be adopted for specific rules in a big ruleset and a quick check is necessary to validate the changes made. Altered classifications mean results become invalid and all rules are checked again and this can be very time-consuming.
              Often it is faster to make a copy of the workfile where someone can recklessly make changes, remove rules, … checks what’s needed to be checked and if time allows/in the best case everything is then federated again into the main coordination model after the task is completed.
              Sometimes you get a call and just need to quickly validate a specific issue with new models. With all the various methods and ways to work with Solibri we have figured out over the years, the above described quick and dirty approach is still the one which is preferred by the users though well knowing it’s not a sustainable one. This is disappointing.
              In the end it’s all about keeping the mind free from unnecessary administrative workload to be able to focus on the actual engineering task and a tool should not slow us down due to limited functionality.
              Time is precious and the solution for this usability flaw is so easy. It’s not easy to understand why this has not been implemented.
              • Alex.JA Offline
                Alex.JA Offline
                Alex.J
                Agreed!
                And I still believe in rule presets (a rule can be useful for different use cases but most use cases don’t need all rules; and we often have mutiple use cases that are recurring on a project)
                  So this is Christmas,
                  And still nothing changed here,
                  Another year over,
                  No progress, just none.
                  Oh, Solibri devs,
                  Are you still there?
                  Our wish is so simple,
                  Do you even care?
                  A very merry Christmas,
                  And a Happy New Year,
                  Let’s hope for some changes,
                  And progress next year …
                    I’m afraid I have to add a new verse this year as well …
                      Well… here we go again I guess … 🙄
                      Another year has passed — it’s Christmas once more,
                      Solibri brings updates, as we’ve seen before.
                      Version 25.12 delivered a few requests,
                      Some long-awaited gifts among the rest.
                      But under the tree, as tradition unfolds,
                      One present is missing, the story retold:
                      “Check only selected rules” — still out of view,
                      A classic refrain, familiar but sadly so true.
                      So we often keep waiting through each full rule run,
                      For just one single result, when the check is done.
                      Every small change restarts the countdown anew,
                      Like Christmas itself — mostly waiting for Santa, too.
                        @JSN Nice to see a slightly more positive verse this time around!
                        Most of the devs are out on Christmas break, but we’ll dig into this again when they come back. I recall that we’ve discussed this topic a few times already, and that there are some underlying technical limitations here and there. Either way I’ll check with the gurus and see what the options are.
                        Toni
