  3. Thickness control within an assembly
1 Posts 1 Posters 328 Views
  • D Offline
    D Offline
    DidierZ
    Hello to all,
    I am looking to control the thickness of the wall layers within the same assembly. How would you do it?
    Example : Name / Thickness
    Layer 01: Siding-16 / 4cm
    Layer 02 : Air space / 4cm
    Layer 03: Insulation / 16cm
    Layer 04: Reinforced concrete / 24cm
    I would like to check that if the name of layer 01 contains “16”, then there must be an insulation layer that is 16cm.
    Thanks in advance for your help.
    Translated with www.DeepL.com/Translator (free version)
