  3. 231 not working with Custom Informations?
6 Posts 4 Posters 1.6k Views
    The rule (property comparison) totally crashes and just shows me the red n white x sign when I am comparing with any custom informations. Is this a known issue?
    2022-09-29 16:23:31.872+0200 [ForkJoinPool-34-worker-3] ERROR com.solibri.sae.greenox.Constraint - Error in running check
    java.lang.NullPointerException: Cannot invoke "com.solibri.saf.plugins.filteringplugin.PropertyReference.getQuantityType()" because "<parameter1>" is null
    	at com.solibri.constraints.construction.comparisonbetweenpropertyvaluesrule.ComparisonBetweenPropertyValuesRule.isCompatible(Unknown Source)
    	at com.solibri.constraints.construction.comparisonbetweenpropertyvaluesrule.ComparisonBetweenPropertyValuesRule.isEvaluationPossible(Unknown Source)
    	at com.solibri.saf.plugins.checkingplugin.rule.RuleSerializedState.isEvaluationPossible(Unknown Source)
    	at com.solibri.sae.greenox.Constraint.runCheck(Unknown Source)
    	at com.solibri.saf.plugins.checkingplugin.ui.CheckingViewPanel$CheckTask.compute(Unknown Source)
    	at java.base/java.util.concurrent.RecursiveTask.exec(RecursiveTask.java:100)
    	at java.base/java.util.concurrent.ForkJoinTask.doExec(ForkJoinTask.java:373)
    	at java.base/java.util.concurrent.ForkJoinPool$WorkQueue.topLevelExec(ForkJoinPool.java:1182)
    	at java.base/java.util.concurrent.ForkJoinPool.scan(ForkJoinPool.java:1655)
    	at java.base/java.util.concurrent.ForkJoinPool.runWorker(ForkJoinPool.java:1622)
    	at java.base/java.util.concurrent.ForkJoinWorkerThread.run(ForkJoinWorkerThread.java:165)
    2022-09-29 16:23:32.028+0200 [Checking] INFO  c.s.s.p.c.actions.CheckDesignAction - Checking ended
    • john.lippJ Offline
      john.lippJ Offline
      john.lipp
      Hi @JSN
      I reproduced this issue with the info api examples
      After saving/closing/reopening the ruleset or smc project the parameter disappears from Compared Component Property parameter in the rule. When the rule runs, I get that same exception in the logs.
      If you close/reopen the ruleset or .smc file is that the case on your end as well?
      I’ve reported this to development as internal issue #676 and included your society post.
        @john-lipp said in 231 not working with Custom Informations?:
        If the error occurs the behaviour of the rule in generel is strange. E.g. I could also observe that the affected rule in the ruleset manager does not respond anymore.
          @JSN We got this duplicated in our development environment and created an issue. We’ll let you know, when it is fixed.
            @Pasi-Paasiala
            Any updates here?
            And btw, any plans to also support custom infos in #203
              @JSN
              This bug is fixed in the latest release 9.13.3.
