Documents API - BIMsync
Hi Solibrians,
after upgrading to 9.13.0.23 i’ve tried to load models to/ from BIMsync.
The connection seems to be established i guess. I got no error message.
But nothing happens when i click the open button.
Upload doesn’t work either. Here i see a popup that Solibri is waiting for the CDE.
Any known issues?Best Regards!
Marcus -
Could you send some pictures of the popups?
Could you also check if the log file is having an error?C:\Program Files\Solibri\SOLIBRI\log\error.logSee the process documented in Help:
https://help.solibri.com/hc/en-us/articles/10233885447447-Using-the-Documents-API-Integration -
@Matti-Kannala
This is the message after clicking the upload button.
I could send you the error and output log. As far as i see the output.log has also relevant informations.
I’ve created new logfiles so they contain less infos for this specific problem.
Opened Solibri, opened a SMC file, connected to bimsync, press buttons open, then upload.
Can i send the logs via mail/ private msg? --> Found private chat and sent you the logiles. -
@marcus
According to the logs, you don’t have write access to this folder: C:\Users\nillma.solibri\bcf -
@Pasi-Paasiala
True. Modified that and now i have access to BIMsync. Thank you!
