  3. Rule: 222 Component Distance
2 Posts 2 Posters 388 Views
    BastiaanVanEssen
    I am trying to create a rule to check if the constructive floor rests on top of a wall, at least 10mm.
    With the Component Distance rule I tried to check a negative distance. The result showed no issues.
    But when I tried running it with values that were wrong on purpose, there were still no issues.
    If anyone has a suggestion to create this rule in any way, I would like to hear it!
    Thank you!
      @BastiaanVanEssen If you can provide a simple model with the rule and say what you’d expect the results to be, we can try to configure the parameters for you.
