  3. Different models coordinates and grids
2 Posts 2 Posters 561 Views
    Modeler123
    Is it possible to check if different models in the project are in the same exact coordinates using Solibri rulesets without checking them visually?
    Also how to check if the models have grids using rulesets?
    Thank you in advance!
    Paul LinderP 1 Reply Last reply
    • Paul LinderP Offline
      Paul Linder Solibrians
      replied to Modeler123 on last edited by
      Hi Modeler123, yes it is.
      For example, if you work with coodrination cubes. In the BIM models, a cuboid is modelled that marks the insertion point of the model. If the cuboids of the individual compartment models are all exactly on top of each other, the positional correctness of the models is guaranteed. This procedure is also sometimes referred to as the “cube test”. To do this, you check for exact duplication, e.g. with Rule 234 Component inside Component.
      Best Regards on behalf of Solibri
