user settings INI file
Hi there,
Is there a ini file wich contains user defined settings?
I like to use it as a back-up, so if for some reason somethings changes (computer failure and get a new computer) and/or Solibri needs a reinstallation.
so i don’t need to go true all settings like units, 3D, Dimensions stamps and things like that.
other files like layout and roles i do have as a back-up. -
@BvanDalsum At the moment most of the settings are stored in Windows registry. (If you’re a Mac user, please let us know and we’ll let you know where they are.)
You should be able to store the settings by making a copy of your registry under the path “HKEY_CURRENT_USER\Software\JavaSoft\Prefs\com\solibri”
Hope this helps.
