Editing rulesets that came with a company extension
how do I edit rulesets that came with a (company) extension? I can’t see and can’t edit those in the ruleset manager.Example: I installed a company extension. One rule in the ruleset is designed for checking components in certain building floors. As my project has a lot of those floors I need to duplicate (add) that rule multiple times in my ruleset.
I can’t see the loaded ruleset of company extensions in the ruleset manager and therefore I can’t add (or remove or whatsoever) rules. Only possibility is to change the configuration of the existiong rule - but that will delete my checking results…How will I be able to edit rulesets that came with an extension? Am I missing something?
(Btw we don’t want to edit the extension itself) -
@MEA you can edit rule settings in the Checking view but not the ruleset itself. Unfortunately, all extensions are blocked from editing, which makes optimizing tedious.
See also this topic: https://society.solibri.com/topic/1995/ito-save-as-save-with-new-name/10
Same thing here. Would it be possible to implement some sort of password requirement if a user within the company needs to alter rulesets or classifications? And then for non-company persons, all the rulesests and classifications, would work, but the inner workings of the rules and classifications would stay empty or protected?
