  3. Checking angle between walls?
3 Posts 2 Posters 686 Views
    Anees Alomar
    Hi Everyone,
    If there a rule to check the degree between two walls if it’s 90 degrees or not?
    Thanks
      replied to Anees Alomar on last edited by
      @Anees-Alomar
      We don’t have such rule. Would it check that all walls within some distance have either 0 or 90 degree angle to other walls.
      How such rule could be parametrized?
      A 1 Reply Last reply
        Anees Alomar
        Thank you for your reply, @Matti-Kannala
        Well, I thought that there should be a rule to measure an angle between two elements, so in this way, I can set a rule like this:
        If a [Komponent] is touching the [Komponent] then the angle should be [X degrees]
        Example:
        If a [wall] is touching the [building envelop] then the angle should be [90 degrees]
        I am just trying to imagine how it might work.
        It could be a 2-step rule as well.
        would that be possible?
